beocenter 9300 how to remove glass panels
Hi thanks for letting me join.  I have just got a 9300 which was sold honestly with some problems.
  1.  I would  like to remove the glass panels and re-do the double sided sticky tape. The controls do not function properly.   Is there a walk through video or instructions to guide me?
  2. The 9300 loses all its presets , it even only plays out of the one speaker.. I know normally this would be the battery but the seller has  fitted a new one.  (he is a tv engineer by trade)    If it isn't the battery what could it be?  Could it be associated with the panel buttons not working  or is there a memory chip that needs replacing.
All ideas welcome. I am in west midlands so if there is any local experts ...thanks again.
Hi and welcome to Beoworld! Firstly, there's a thread about the earlier BC9500 which may be useful here: ) to see if that cures the fault. With regard to the missing channel, try connecting the speakers to the speaker 2 sockets.  If these work then the muting relay (which  only supplies speaker 1 sockets) is faulty and should be replaced. Finally it would be worth having the service manual (available to Silver/Gold members of this site). Let us know how you get on, and if you have further questions. EDIT:  Forgot to say - I have always used super glue gel to re-stick BeoCenter glass panels, rather than double sided tape (as described in the first thread that I linked).  No problems after further 15+ years of use!
Thanks for such a detailed and clear response. I'll have a go at everything you suggest and get back to you.   Id like to get this work of art in good condition.   What is the situation with replacement remote control for the 9300. I don't mind aftermarket .   Thanks 🙏
<!--more-->
Followed instructions, Made a couple of errors but all buttons up and working perfectly. I could see the glass panels had been dodged slightly before. I'm now thinking the battery is probably the problem. Is it a desolder and solder job? I'll need a second hand remote. My finances are pretty rubbish.
Great work so far - glad that all the buttons work! Yes battery replacement is a soldering job, and you need to be careful not to apply too much heat as batteries can explode!  (Wear goggles) EDIT:  I have just deleted some of the advice and photo because I believe that the BC9300 battery may be in a different position to the BC9500 - I will check!!!!! And the battery type that I have fitted in the past:
Further to the above, although I don't have any photos of exact location, in the BC9300 the battery is actually on PCB3 which is the microprocessor board.  This thread may help:
I've located battery. I can't see any soldering on top, is it soldered on the other side? Are the white pads under the battery normally there? Could you have a look at supplied photos. Thanks.. I'm very close now.
<!--more-->
