Hello,
I recently did some tests with the version 4.11 of the config tool. I worked on a standalone PC and did not connect the BEO5.
There are some problems I discovered regarding compatibility of my configuration files. The new tool looses the manually created settings of step "edit". Loading a configuration the tool acts as if you modified the product configuration. All the macros created, colors set, button positions etc. are lost.
Has someone experiences yet, regarding the new firmware?
I would like to take the decision, weather it's worth the pain migrating my configuration or not.
regards hfat
