Home › Forums › The Workbench › Help with Beogram 59XX resistor replacement › Reply To: Help with Beogram 59XX resistor replacement
17 October 2022 at 00:45
#26328
If you are referring to the resisters in the lower right where the board is darkened, those are 1/4w resistors which are typically 6.5mm in length. You will not find a replacement parts kit that includes standard resistors. I would check their values with a meter as even though the board is discolored most are probably fine when the resistor itself is not blackened in the middle.
