Home › Forums › Product Discussion & Questions › Vintage Products › BeoX remote question › Reply To: BeoX remote question
29 July 2022 at 10:32
#28077
However, it does not remember the order you add the LIST functions. If I add V. TAPE 2 first and then SPEAKERS, SPEAKERS come up before V. TAPE 2 anyway.
When you add a new function it moves it to the start of the LIST by default. Hence you should add functions in the reverse order that you wish them to appear, if that makes sense.
In the meantime it could still be worth trying that ‘decoder’ trick that I mentioned in my last paragraph.
