July 17, 2022 at 7:54 pm
#6825
Hi and welcome to Beoworld.
The Line in-Line out connector is important because it need to be bridged with a special plug for the Beocenter to make any sound. I can see the plug but if the connections are broken (obvisously they are!) it won’t work.
Maybe you can bridge the broken traces by soldering wires (maybe they’re not much) and find an trick to keep the broken pcb part in place. If you need to use the connector for Aux-In, plug the cable in, secure it with anything and let it like that taking care to not applu too much strength on that side.
Of course, Guy’s advice is the way to go but meanwhile that should work.
