Home › Forums › The Workbench › BeoSound 9000, Laser dirty › Reply To: BeoSound 9000, Laser dirty
6 July 2022 at 10:20
#28429
When you try and read a CD does the disk make a small movement, then the words “Pause” appear in the display. If yes, then the laser is 99% the problem.
For the Mark 2 & 3 the laser assembly can still be obtained. However, if you have a Mark 2 BS9000 there are two different laser assemblies.
