Home › Forums › General Discussion & Questions › How do I fit a Beosound 9000 table stand? › Reply To: How do I fit a Beosound 9000 table stand?
2 July 2022 at 15:26
#28538
Hi Stoobie,
You can use the user manual for the STB Bracket stand. Although not exactly similar, the principle is the same: slot in the bottom, bolt and spacers at the top.
You have also a diagram in the service manual but I beleive you already seen it.
The holes in the BS9000 are the only ones apparent. When you hold the unit in front of the stand (or the stand below the unit) they should reveal themselves.
Hope this helps.
