Home › Forums › General Discussion & Questions › B&O Beosound Century Remote Control Troubleshooting › Reply To: B&O Beosound Century Remote Control Troubleshooting
23 June 2022 at 09:51
#28756
the repair of the IR Board is indeed simple 🙂
Replace the two silver SMD caps. If the space allows you can replace them with ordinary electrolyctic capacitors ( 22µF / 6.3Volt ). To remove the old capacitors hold the PCB and with twist each capacitor with a plier. This way the cap will be removed from its base without tearing the traces. Now remove the two pins soldered to the PCB and clean the board with IPA and solder the new caps to the board. Mind the polarity!!!
