Home › Forums › General Discussion & Questions › Connecting BS3000 to BS Core › Reply To: Connecting BS3000 to BS Core
22 June 2022 at 18:25
#28767
BLC
- BLC set to A.Slave
- Experience mapped to NL: check the BS3000 sources
- note: you can change the name of a source also (for example CD to BS3000 CD)
- Note confirm the steps with pushing the Store button.
- Note: you can give it its own name: set Friendly name in NL
Core
- goto Core configuration pages
- choose: setup – link to other product – set primary to the BLC (= Friendly name in NL)
- press button connect
Play a BS3000 source:
- start the app
- choose Core
- click black bar with Core (above Home)
- choose the three dots
- select the BS3000 CD
now the CD from the 3000 should start to play on the BL20 connected to your Core
