June 15, 2022 at 8:11 pm
#5907
The short answer is Yes
The long answer is most older B&O products had mains transformers with two primary windings.
When the two primary windings are put in series its for 220 volts and in parallel for 110 volts
The CDX has such an arrangement as you can see from the image below taken from the CDX manual. Apologies for the poor image quality
