Reply To: BeoSound 5 screen dead?
#5854
ethuijs
    Hi Griebel, as the BM5 is just a XP PC may try to connect an PC screen to the BM5. I think its DVI connection but follow the cabling from the BS5 and you will find the connector. A harddisk failure could also be the problem. On the old forum fixes for replacement of the HD are documentend. Kind regards, Edwin
