Home › Forums › General Discussion & Questions › Beolab 8000 with Step-Up Converter › Reply To: Beolab 8000 with Step-Up Converter
27 May 2022 at 09:54
#29239
I would have thought you will be fine with a step up transformer of 100w if the load of each is 12W will be more than plenty. I had this the other way round for a while with the some speaker I got from Japan – I used one transformer on each to save running cables, but one one transformer for the pair should be fine.
