May 5, 2022 at 11:01 pm
#4797
Just to be clear, and add to possible answers…
There is the DIN input that I believe to be a service input only, never meant to be use as it.
There is the masterlink input (large rectangle socket) that is THE usual input. It is analogue but it need some dark digital protocol to be started.
Assuming this is right, I’m with you, how couln’t we just keep the beolab with one or the other input as default? Even more, use the Masterlink port on any device as an additional Aux in? Even if it needs to short anything inside.
I really think they are more Beolab 3500 unused than Beolab 3500 used as link room speaker… So sad.
