Reply To: How to connect a Beolab 3500 to BM7000
#17324
filip_kbh
    • Topics Started 4
    • Total Posts 41
    I have now tested for continuity between all pins. There is only continuity where there should be continuity. My money is on the BM7000. I saw Die Boegener made reply to someone around datalink not working after a thunderstorm. Since I did not have my BM7000 since the beginning, I have no clue what has happened to it previuosly.
    At https://archivedforum.beoworld.org/forums/p/28464/223667.aspx he replies:
    some parts in the datalink section are dead. Nothing special, 50 cents on the pre amplifier board.
    Replace:
    D5= 12V zener diode 0.5W
    TR1=BC547
    That’s all…
    Not sure if I should look into that at some point.
