Home › Forums › The Workbench › missing BG4000 › Reply To: missing BG4000
23 March 2022 at 11:33
#30121
As I’m now down to 1 bridge rectifier I thought it would be wise to check a few things out before I do a lengthy test run:
Output from the new 6vdc regulator = 160ma under operating load
Output from the existing 24vdc regulator (0tr1) = 440ma under operating load
The transformer arms are good for 1.25A so I think we’re good to go, the bridge rectifier is rated at 3.7A. I will monitor the temperatures of all components, TR1 particularly though the data sheet says its good for 80w (seems high to me).
Also I have ordered a 33 ohm 3w resistor to see if I can drop all the heat over it instead of the regulator, I can then fasten the resistor to the chassis for cooling……
