February 26, 2023 at 8:16 pm
#16718
I still utilise the BS6500 in the office and needs to have the speakers connected directly, and don’t care about audio from any other sources from either ML/NL devices.
Be aware with the proposed solution you can still listen to the speakers now connected to the BM6500, but then they are connected to the BM6500 BLC.
You can start all the sources of the BM6500 with a remote if an IR eye is connected to the BM6500 BLC (or use the B&o app) and play these sources to the Beovox 100 and Cona BLC connected
