January 10, 2023 at 11:22 pm
#14004
I would expect about 0.7v forward and 2.7v +-0.1v in reverse (since it is a zener diode).
You might get a misleading reverse voltage reading depending on your tester. Testing with a series resistor, voltmeter and a power supply can be used to verify the reading.
Glitch
This reply was modified 3 weeks ago by
Glitch. Reason: added info
