8 November 2022 at 15:22
#25605
I’m used to “tap/press to join” with my older Beolink devices (BS 1, M5, M3, Core + Essence Remote), or, when no other source is playing, resuming a local source.
If the Classic mode is disabled, this no longer works (i tested it), a tap/press starts a local source instead and documentation says that a long press is required to join which not all device can do, e.g. BS 1.
Also, I’m used to uses long press where supported to shutdown all devices. Reason why I kept Classic mode enabled.
