Home › Forums › The Workbench › beogram 5500 turntable repair, gear disassembly? › Reply To: beogram 5500 turntable repair, gear disassembly?
6 November 2022 at 10:52
#25689
Yes….and since it worked until I removed that bent part 1609 & reassembled the gears ( improperly? ) it highlights how important it is to make sure the gears are assembled correctly!
The service manual is a bit crypic regarding the orientation of the gears.
