Home › Forums › General Discussion & Questions › Beomaster 1100 bulbs › Reply To: Beomaster 1100 bulbs
1 November 2022 at 14:46
#25849
A lamp of 12v 80mA is always the same no matter
As explained at the Beoparts link, in the BM1100 the stereo indicator bulb is part of the tuning circuit, with current varying with brightness. This won’t be linear due to temperature effects, hence it is critical that the bulb behaviour is correct. Many others on the forum have had similar problems in the past with indicator bulbs that purport to be the correct spec, but do not work in this application.
Of course there may be other (non-bulb related) problems in your tuning circuit, and perhaps others can suggest a solution.
