Wall mount BV 6-26
salut
as above anyone??
bonne noel
Tony
would have a 7-32 bracket, it's almost identical if you remove the lower part that holds the Lab 7-1 speaker...
Is it possible ?
have you pics?
pm me if above are easy together with a price
salut et bonne nouvelle annee quand il arrive
tony
Got one, - thanks root
bonne annee!!
tony
