Beocenter 9000
Hello! I'm looking for a Beocenter 9000 in pristine condition
with box and manuals! Hope to find one!
Many thanks,
Alkis
i have both a 9300 and also a 8500 both unblemished(i think) pm me if interested
tony
forgot to add the 9300 is complete with box and manuals - it is however currently in france!
tony
Thank you very much for your message but I'm looking
for a Beocenter 9000 only...
Best regards,
Alkis
Alki kalimera.
Ligo diskolo gia 9000. Giati mono afto to sigkekrimeno?
 Filika
Spiros
Hi, i am based in Singapore. I have a beocenter 9000 with upgraded CD mechanism(with clamp) changed by B&O Singapore. The set was sent in for the change last year and checked. The trim is in bronze and i believe the new CDM will last you many years to come. You may find a set with old CDM but you have to be careful as it might breakdown half way through.
My old original box was thrown away due to the humidity problem but i have the after-sale box from them which i got it for my BC9500. I am not able to find the manual unfortunately. Let me know if you are keen and make me an offer.
Hi, i am based in Singapore. I have a beocenter 9000 with upgraded CD mechanism(with clamp) changed by B&O Singapore. The set was sent in for the change last year and checked. The trim is in bronze and i believe the new CDM will last you many years to come. My old original box was thrown away due to the humidity problem but i have the after-sale box from them which i got it for my BC9500. I am not able to find the manual unfortunately. Let me know if you are keen and make me an offer.
I have a beocenter 9000 with upgraded CD mechanism (with clamp)
Hi flex73,
I also have a Beocenter 9000 and I wouldlike to upgrade the CD mechanism. Could you please let me know more about your upgrade with clamp? Thanks a lot for that.
Kind regards,
Jean-Sebastien
Hi js,
Sad to say or i believe that the CD clamp mech. type replacement for the beocenter 9000 is no longer available with the service center,  i do not know if they still have it at your area, doubt so :( .I was lucky to get the replacement done, believed to be one of the very last still in stock at my svc center.:). Even the newer BC9500 parts are obsolete now. Basically, the new mech requires you to clamp the disc before you play as opposed to the old fragile clip type which originally came with the 9000.
flex73
