2-pin DIN speaker cables
Hello 🙂
I was just wondering could anyone recommend me where to obtain good speaker cables for my Beovox M70's? I see that there's a couple merchants selling these cables on eBay, but might there be even more alternatives preferrably here in European Union?
Unfortunately I've had a bit bad luck with AV Solutions (cracked connector covers on both shipments, not that good quality in my opinion) and Sounds Heavenly has only 5m and 10m lengths available at the moment (though they were willing to help me get them shortened!).
Regards, Jouni
Hello Jouni!
Let me know what cable lengths you are looking for, as you are a BeoWorld member I will do my best to help! 🤒
Best regards,
Steve.
Make them yourself and get any length you want. 2-pin DIN connectors are available in just about any electronics store (and even Biltema), and 2x0.75 mm2 lamp cord is plenty good for speaker use (heavier than B&O factory cables!).
If you'd rather have molded connectors, I believe the cables are still available at the dealer, and the prices aren't that big.
Although I'd just get the 5m cables and wrap the excess up, you'll want to move the equipment sooner or later anyway...
I have used both iconic-av and Sounds Heavenly for cables and would highly recommend both. They are both members here.
Simon
