Clean the track rod that the laser block slides on using isopropanol (tapehead cleaner) and a soft cloth. Step to outer tracks on a 70min+ CD to access the inner part. Clean also the tiny bearing ball at the left side bracket (a couple of screws to go there). Give the ball and track rod a little sewing machine oil, step the laser block through the full travel a couple of times (by inserting a 70min+ CD and skipping tracks forward over and over). Add another drop of oil to the rod. If it's very dirty and lots of dust and dirt are pushed out and accumulated at the ends of the blocks travel you may need to clean again.
