Sound delay ?
Hi
I was running a DVD1 by fully wired scart to my 8-32 tv, and was using the tvs internal speakers to watch a dvd - all good.
I had the sound output from the DVD1 direct into my existing Pioneer A400 amp and running out to my B&O RL45s
What i found was there appears to be a delay/minor echo when listening to both tv and amp at the same time.
Is this by design? Or is there a delay with sound running through scart to the tv?
Any thoughts appreciated.
Cheers,
synth wrote:
Hi
Cheers,
The internal speakers in bv8 are delayed because all lcd/plasma panel have a delay for the picture and then also sound have to be delayed
so if you connect your pioneer to tv instead you have the same delay
