Bonjour,
I need to replace a woofer and medium speaker on RL 140.
Does anyone know exact specifications for these two speakers since I'm going to try to find new ones?
Thanks for your help.
Regards.
Alain-Olivier.
Bonjour,
Regards.
Alain-Olivier.
If the foam surrounds have rotted and are falling apart, they can be repaired.
If one shows rot, the other three will also be bad or at least marginal.
If a woofer is no longer playing, it will most likely need replacing.
The woofers are 6 ohms and will be hard to match with modern types.
I have a set of original woofers, refoam'ed and ready.
No midranges though.
Thanks for your answer Martin.
Would you agree to let go of one woofer only as the other three are functionning and newly refoamed, and at what prize?
Regards.
Alain-Olivier.
Sure, you have a PM (check your inbox at the extreme top right corner of this page).
