I don't know what all that crap is above my post but I can't get it to go away. Looks like CSS code. Anways, my post starts below:
I spent the last 12 hours disassembling and reassembling this table trying to fix a few tonearm issues and found it remarkable that not one of those times had I broken anything. Well this last time I reassembled it, there was no audio output. I could hear the output engaging and disengaging (a subtle pop noise through my speakers) as the arm drops and raises so I disassembled the table yet again and found that 3 wires had ripped from the solder joints on the omron audio output PCB. If it helps at all, the model is Omron G2V-2 12 VDC.
I guess what I came here to find is either a wiring diagram, a picture of an already-wired PCB, or some other clue as to which wires go where.
Thank you to anyone to responds.
