If the goal is to achieve original sound and general functionality, I must say
that I don't agree to replace all components on sight.
I never do anyways but rather try to stick with originality as far as possible and let vintage be vintage.
Menahem tend to prefer replacing all components that he can find modern substitutes for
in an attempt to reach a higher degree of stability or linerity or something else.
He knows that I don't always agree with him, I respect his choices and paths even if I
don't always understand them. He works in a different way than I and this is not to
stir up a discussion but it's a fact that the original circuit was never constructed
with 40+ years future components in thought and lots of the modern components would
perform much better if the circuits themselves too were re-engineered.
But then we would end up with a modern circuit with modern components and you can buy
that in nice plastic casings in any HiFi shop today. Much cheaper and with
remote control, USB 2.0, wireless network and no bigger than a pack of cigarettes.
It would never be a Beomaster 1000 - but that's just my opinion.
The number of capacitors in a Beomaster 1000 is not that high so it would
not be an impossible or too costly task to replace the lot.
If physically broken, leaking or otherwise proven defective they must be replaced
and in most cases you can apply the rule that if one cap is bad, others
of similar types in the same machine will also be, so that will save you some measuring
and you can do all the shopping in one go.
Personally, if the radio is performing well by then, I wouldn't worry too much
about resistors, transistors, diodes etc.
If the components are still working, they will have proved their reliability and there's a good chance
they will continue to do just that.
The old components will have fairly large tolerances on their values but the radios circuits were
constructed with this in mind.
A Beomaster 1000 is a wonderful radio in its own right. I have quite a few in
my own collection, more than sanity allows, and I've repaired several from all over the world.
Everytime I have one on the bench I sit back and listen. I truely enjoy the
wonderful sound it produces.
Yes, it may not have a completely linear frequency response.
Yes, it may have a slight hint of background noise, especially if its an early (germanium) version.
Yes, it's not a modern construction.
But that's how it was intended.
Allow it to play using contemporary B&O speakers or slightly newer, Beovox 1000
or preferably higher, and I'm sure you'll also be amazed.
