Well
I have done some control measurements. Controlling the supply voltages for the circuits on the CD Pro2 board. They seems okay.
I returned to the issue, that the spindle motor did not rotate, even that it got the service command "TM 63", if i rotate the cd with the fingers, im able to hear some acoustic noise.
I can se a wierd triangular waveform at the terminals of the spindle motor:
Notice the frequency, ~176khz, wich is noted as the upper frequency limit of the TDA7073 driver. Maybee something is oscillating?
I cant see this waveform at the input of the driverstage!
Checking the other output from the driver stage (wich drives the focus) seems to work. It tries to focus, and the laser moves nicely back and forth
I have also investigated the communication from the main µProcessor board to the cd mechanism. But it seems okay in both directions.
It could be nice with some input guys!
Thanks in advance
//Thomas
