MX4000 Picture with black stripes
Hello Beoworlders,
a few weeks ago my MX4000 (model 7870 from 1998) started to have black stripes and shadows in the picture. The stripes are not always visible, so it seems to be a slack joint or a dying component. This is how the picture looks like:
A soft knocking on the top of the black back cover of the TV solves the problem, but the stripes come back after a few minutes.
The stripes also appear in teletext and external AV sources.
I have seen the MX4000 workshop (http://forum.beoworld.org/forums/p/24571/191760.aspx#191760), but i am not sure if my problem is related to the fixes in the workshop.
Thanks for any tips
Bernd
Looks like a problem on the vertical deflection ... most probably that 2.2uF cap in the drive line.
Hi
Replacing the caps C131 and C134 , 470uf 16v use to solve this problem.
Best regards
Trigi
(Denmark)
I finally found some time to recap the mainboard as described in the link. A complete success 🙂
The problems with the picture are gone and I'd say the picture is now as good as new.
A good source for the low ESR caps is the .
Bernd
