LC2 wall mounting
Hello
I've got an LC2 that I'd like to use as a light switch replacement, but I need some ideas on how to fit it in to the switch back box. I'd rather not surface mount it with the wires showing if I don't have to. I'm happy with the wiring, it's recessing it in to the wall that's baffling me- all the holes are in the wrong places!
Thanks,
Edd
I used a blank switch plate and machined a hole in which I mounted the LC2 following advice from a B&o installer.
