How do I remove a stuck VHS tape from a Beo Vision Avant 32"
An old tape is stuck in the TV how can I extract it without causing any damage?
Rgds
TJB.
It's a V8000 drive?
Open the drive, probably the "worm gear" is defect. You can turn the gear manually and release the tape.
It's the most common defect of this drive and can be repaired cheap and easily.
