Disassembling a Beo4
My Beo4 remote got left out in the rain, and now all it does is say "TV", and if I any button it goes to "V.MEM".  My guess is that there is a bit of moisture trapped around the buttons.  Does anyone have experience in disassembling the Beo4?  I removed the back and the 3 small screws.  However, the front plate with the buttons/screen is still firmly attached to the ends of the main body while loose in the center.  I'm guessing that there is a trick with the plastic shield over the LED but didn't want to force anything unless I knew that to be the case.  Thanks.
Do you know why they call it Beo4? Because it has 4 screws 😕😂
See the red dots on the picture below
Remove the metal clip that holds the plastic contact "board" and clean carefully the contacts. The ones on the plasic are very sensitive. This solved the issue with my Beo4.
Good luck, Marcus
Thanks, marcus_m, that fixed it!  Just to be clear, there is a small, corrugated metal clip that presses the contacts from the circuit board to the clear plastic liner that cover all the button bubble contacts.  It is located between where the red and black wires from the battery feed into the circuit board.  I removed that clip, and peeled away the plastic liner just a few mm and cleaned in there where the contacts meet, and replaced the clip.  I did not pull back too far for fear of warping the plastic structure or breaking open the bubbles where each button's contacts are located.  My guess is that those bubble portions are already well sealed and fairly impervious to water seeping in.
Unfortunately, after just a few hours the Beo4 reverted back to its permanent V.MEM display.  No amount of opening and re-cleaning of the contacts has made any difference this time.  So, I'll just assume the Beo4 is permanently hosed.
Just get a new 'bubbly' bit from your dealer. It should only cost just over a tenner (£10)  Be careful when peeling off the old one though.
Andy T.
Sorry Craig, I couldn't think of the name B&O calls it last night. They call it a Dome Foil (thougfh there's nothing foily about it)
Andy T.
