Disassembling a Beo4
Do you know why they call it Beo4? Because it has 4 screws 😕😂
See the red dots on the picture below
Remove the metal clip that holds the plastic contact "board" and clean carefully the contacts. The ones on the plasic are very sensitive. This solved the issue with my Beo4.
Good luck, Marcus
Just get a new 'bubbly' bit from your dealer. It should only cost just over a tenner (£10) Be careful when peeling off the old one though.
Andy T.
Sorry Craig, I couldn't think of the name B&O calls it last night. They call it a Dome Foil (thougfh there's nothing foily about it)
Andy T.
