Dirt behind glass panel Beovision 6000
Hi all,
My Beovision 6000 has, gathered over the years, quite some dirt at the backside of the front glasspanel. I would like to clean this, but i'm not sure how to.
Is there a way to remove the glasspanel or do i have to detach the tube and the electronics from the back to reach the backside of the panel ?
Thanks in advance.
Marc.
Marc,
remove the plastic trim just above and below the screen (use a small screwdriver to prise it away at the sides of the set). Then undo the four philips screws and remove the contrast screen takeing care that it doesnt fall forwards.
Good Luck
Dear Sgreswell,
Thank you very much for your instructions, i'm looking trough a clear panel again. Forward for the next ten years 🙂
Greetings,
Marc.
