ok strange!
had a cig, grabbed a screwdriver.
came back, and... now there is a display!?!?
it says:
.7 TP0
++++update++++
ok. got in. amazing for the general build quality that they did not use better connectors.
nearly all of the connectors were loose. a bit of fiddling and the control panel started working.
threw some p45's and an antenna on, viola! sound.
ok, now no tuning. the center board w/ the "stores" was ajar as well. clearly someone had been in before me as the backing tabs for the buttons had broken allowing the circuit board to push in freeing all of the buttons from their respective keepers.
i have that going back together right now w/ a little help from my second best friend, epoxy. time for a cig.
more later...
++++update++++
ok. "stores" board back together and installed. filtering and stores works fine now. back to the tuning problem.
i knew the volume side worked, so i started there. jumpered around until i could get the vol up and down w/o using the optics. tried same on the tuning side, and got it to move from 106.7 to 106.8 haha! the solders looked bad. clearly had been reheated in the past. reheated again, but no luck. so i manually "jumped" all my stations and stored the presets. i could go the "redneck" way and leave it as is, but it appears (bad pun) that the optics are bad on the tuner wheel pickup, and i would like it to be right.
anyone out there maybe have the optics board with leads attached? i am going to go ahead and replace both volume and tuning, so ideally i'd like to a find a pair. i would also entertain the entire push button panel with the leads attached.
at any rate it is running as is for now, and surprisingly the displays seem to be intact.
