I don’t remove any wires at this stage.
I only pace the filter at the top of the cabinet and do the work here. I suggest using some protection between the filter and your Beovox 5000.
The process require a few changes to the filter because the new caps are physical much bigger and more heavy.
I will rearrange and I will use hot melt gluing of the caps.
This is the result of the rearranged part for the crossover filter.
The reason for gluing the parts is of course avoiding noise and vibrations.
more to come 🙂
Sure looks crowded, I dont see the 3rd coil, is it hidden under the 68 Mu cap, and did you glue the cap to the coil ??
Printing machine technician
Rock and Roll music
Collecting Vinyl
