HiI have been given a beovision 3/32 today which has the following problem which I have just made a LOT worse. Initially it just dropped a green colour as it warmed up, when right the picture was great which i saw for about a 1/2 hr. i then removed the back and looked around it appeared not to dirty so i Carefully applied power... redish mostly picture with bright red flyback lines.... I then Gently dusted the tube neck pcb with a paint brush it shorted then the set cut out!!!! yes very stupid of me! it will now only respond to remote on /off after removed from power for a few mins. It will power up with only red screen with flyback linesfor approx 5 seconds then shut down...
any help much appreachiated
Regards Maurice
