Beosound 9000 Typ 2571 MK3 Do not play CD's - Focus error
Got a BeoSound 9000 type 2571 EU. As the Service Menu shows CD error No.2 Focus
Before I get to order a new service CD kit from B & O,
I want to hear if anyone here knows if it goes to service the BS9000 without having replaced with a new CD laser and associated circuit boards?.
Sincerely
Jan
If you are lucky then the laser lens needs cleaning but in all probability the cure will be a replacement laser kit.
Make sure that you order the right kit for your model as there are several, depending on the type number of the 9000
Hi Graham, I received today the CD laser kit, but before I began to work to change the CD laser I tried BeoSound 9000 and now see what happens my BS9000 works again.
It was still unused since 23 April 2011 now works again.
I have no idea about the error come back?. Hopefully not.
It could have happened with control of the CD laser, that I also cleaned the laser.
We'll see, I will come back.
Regard Jan
Hi Graham, the error came back so I'm changing the laser now it works well.Trying to serve BS9000 with CD errors, Without a CD laser kit is time consuming and can not serve 100% good.
I replace the CD laser in less that 60min. The cost was 1500, - sec, about 120, - GBP
Regards Jan
I usually does require a replacement laser kit for a permanent cure.
