My other wise perfectly functioning Beousound 3 (radio shaped like amilk karton) stopped responding tomy commands.
I have tried to remove battery and dc suply in order to "reset" it, but is still does not work - I cannot activate the radio og get the antenna up.
The problem occured after i programmed the timer functioning,
Do you have any advice?
Regards
Christian
