The trimmers were set to match the amplification etc. of the IC's on the other board...
If I get this right, you swapped the output stage IC's board with another one and
then the trimmer settings were no longer correct.
This damaged the amplifier board (and maybe also the IC board).
Then you mounted back the original IC board to the amplifier module that was now
bad. Then the whole thing burned...
Sorry for me asking this, but are you educated in electronics in any way ?
Don't get me wrong, but DC-coupled amplifiers like this one can be very hard to service and
many repairers, even experienced ones, fear them like the plague for the same reason.
When everything is fine, they are some of the best you can get but one little fault in a driver
or predriver can set off a disaster in the following stages, destroying components as the avalanche rolls.
If you are not familiar with DC coupled amplifiers, I suggest you leave servicing to someone who is.
The risk of damage, personal injury and fire is very real and compared to the cost of having a
Beomaster serviced professionally, not worth risking.
- not that it matters much now, but did you check the bipolar cap, I suggested ?
