I hope someone can help me solve this problem:
I have a 80s Beomaster 6000 that I bought as a spares unit some time ago.
But now I finally wanted to restore it and I'm having a little problem:
I tested all boards in an other 6000 - they all work fine (well, the output amplifier has some problems, but thats another thing).
The only thing not working is the power supply.
As soon as I plug it in the 160mA fuse blows. So I can't even measure the voltages.
I replaced the obvious faulty parts first - C20 and 21 (the two big caps) were leaking. Sadly I couldn't get a hold of -10 +50% caps, so I used +/-20% ones.
That didn't change anything...
Is it possible that this is caused by a broken relay? The BM had some kind of water (or rather oil) damage - this (hydraulic?) thing that opens the programming lid leaked and the relay got 'wet' (at least on the outside, looks ok otherwise).
