Hello,
I would like to ask for help with my new Beomaster 5000. I have some issues concerning radio section of the unit.
Problems:
- Most important problem - no stereo FM reception. FM in mono mode plays extremely well, sensitivity is very high and quality beats almost everything I have. But all other tuners on a just a few centimeters of wire can tune in to the local stations in stereo mode - Beomaster event with a good antenna can't. I started troubleshooting the problem by looking at TCA4500A - stereo decoder. I tried adjusting the 5K pot for frequency oscillator but with no luck (returned to the first value). I also measured the signal from CPU switching the decoder to mono/stereo (pin 9) - it changes between 70mV and about 2.5V when selecting FM MONO on the front panel (but the STEREO indicator never appears) - it seems that the signal from CPU is correct. The stereo-indicator output pin (number 7) doesn't change at all. I also tried to measure frequency with multimeter on the pin 15 - I get about 150-190 kHz, I don't know if that's correct. The supply to the IC seems to be ok, about 11,3V. TCA4500A does not get hot - I read that it is a typical symptom of damage. Currently I have no idea what should I check next.
- No MANUAL tuning indicator light. I can switch to MANUAL mode on the front panel and then tune manually, but it is not visible as MANUAL text on the display. Is this indicator a LED?
What I did so far:
- full recap of preamp board
- full recap of amp/PSU board (including big 10000uf cans and 4700uf cap)
- new 100ohm cermet trimmers and adjust of idle current
- adjust of +5V voltage
- new caps for CPU module + new 3V battery
- new caps for IR transceiver module
- partially new caps on the tuner section (changed 2u2 near TCA4500A + 100uf near TCA4500A + almost all 10uf)
- new 5K cermet trimmer for generator (if this term is correct) of TCA4500A
If you have any idea what might be wrong or any hints for me - please help :) I have a good multimeter and oscilloscope at home so I can measure anything that you might consider important.
Best regards,
Marcin
