Beolink 7000 recap?
Can anyone please recommend someone who can do (and knows) a capacitor renewal on my immaculate Beolink 7000?
The machine is in the London area and I don't really want to send abroad.
Any help appreciated.
BF7
9 days and no replies? Surely someone (other than Smarties) has the answer?
Might be worth contacting Tim @ Beocentral?
What makes you think it needs recapping?
I seem to remember Die_Bogener did a couple of these.
Do a search in the fora.
The job is a bit of a pain in the butt, that's one reason why people are keeping their heads down.
Member nobby (Neil Briffett) does repairs so suggest that you contact him by PM. He is in Farnham so not a million miles from you.
If not mistaken, Leslie had a thorough/detailed post on this subject. From what I had the chance to see although it's a time consuming procedure is not a very difficult one.
You have to be very careful with the flatcables and the display. And you have to use special smallsized capacitors, otherwise it will not work.
I personall would not touch it unless absolutely nescesary.
You need some skills to do the job!
Check this on my Picasa
I would replace all capacitors in BeoLink 7000. In most cases the other capacitors are also leaking and it is just a matter of time until you have to open the BeoLink 7000 again.
