Sorry guys, the cap 680uF replacement was no succes!
Have replaced all capacitors (11 pcs) but the on/off issue remains.
Gonna use that one for my LCS7000 wall charger🙂
Awww ok, I will prob also use one of my defect BL7000 in a similar way, but always in a tablecharger hehe.
Thanx for testing it out for me and i will in a near future try to change the piezo since I have found a swedish provider to the right size :D.
Again, thanx
Jesper
@Leslie, sorry for bugging you again but saw now that you had a LCS7000 (very nice indeed) and I personally have a floorstand for my BL7000 and I think that you and I have same powersupply. I hope that maybe you have the wallplate to mount the powersupply on a wall. From the powersupply it seems too be a round thing with two "hook".
I hope maybe you have photo of it, if you have it that is, so i can try make my own :D
Cheers
Jesper
Jesper, I wish I had one. Funny enough I never installed the LCS7000. It just sits in a box and still don't have any purpose for it. That's because of the Xtra speaker I got with the LCS7000. ALthough I got many advises how to connect this kit, I still haven't got the chance to install it.
It is amazing that so many of these have this same common fault!
Well, I guess I'll be relegated to using it in the charger as well!
Need to find a LCS -that would be best!
I never put my BL7000 back together after these threads -hoping that someone might have a solution.
In the meantime... any confirmation from users that the BL7000 remains stable when used solely from the charging stand?
My "bad" BL7000 still works all fine in charger but to be honest I dont use it that much since i have a "good" BL7000 that is my joy :). One downside with the "bad" BL7000 that im abit worried that I never "execise" the battery in the same fashion I do with my "good", since the "bad" mostly sits in the charger.....
Cheers
Jesper
@ Leslie, I did a recap and battery replacement and that resolved the issue for me. Can be viewed in this thread here
http://forum.beoworld.org/forums/p/35867/297765.aspx#297765
I would do basic check:
Battery is good and producing 6 volts?
Pin 10 on the ribbon cable is at 5Volts when BL is on and 0 volts when off. If it is, then issue is with the analogue board. If it’s not, then issue is the digital board.
Check with a meter that there is continuity in the ribbon cable ie. No break.
Reseat the ribbon cable.
Next:
If you have two BL’s try compare voltage readings on same parts of the board between the two.
Good job MartinM! I have 5x BL7000 now and one of them is still having this issue.
Hopefully the options you mentioned will solve it! Will keep you updated, for sure🤒
Leslie
Check the voltage of the back-up battery on the microprocessorboard.
