Beolink 7000 keeps switching on and off
I have tried it (found a room with no B&O Peter! 😁), but same story. The problem is actually literally described as a fault in section 2.7 of the trouble shooting chart in the service manual. Since the service manual only advices to replace either module 1 or 2 (which are no longer available), it is of not much help.
Hello Die Bogener!
If it is the sensor, wouldn't it be switching on and off, even when in the charger? It now only switches on and off when taken out of the charger.
Hmmm, then it cant be the sensor.
There are 2 switches on the backside at the lower end of the BL7000. These switches are responsible for the motor control. What happens, if you put it on a desk, will it move? And if you put it on the desk with a small distance that these switches are not activated? Will it switch off?
What voltage can you measure on the battery when it's operating? 6V?
I have been reading on the forum that more people have experienced this problem since I started this topic. Member ''Die Bogener'' suggested recently that replacing the big blue cap on the lower PCB board could solve the switching on/off problem. Has anybody tried this replacement and has it solved the problem?
