I recently applied Medogsfat's hinge fix to a CDX I aquired. During the CDX hinge repair I also had to adjust the button pads that control the player to fix some of the buttons not working. I got all of that working and have been using the CDX for a few weeks. It has been working well. In the last couple of days though, it started having trouble initializing. As the tray lowers the disc to the motor when the door closes, the disc often gets spun out of position. When it does lower correctly the laser is often not recognizing there is a disc. Do those issues usually stem from some of the detection switches getting out of alignment? I haven't moved the CDX player at all. It has been sitting in the same place...and suddenly it stopped handling discs properly. Either something failed electrically or movement of the lid opening and closing knocked something out of alignment. Has anyone had this problem with the CDX type players?
-Sonavor
