beogram 6006 platter not moving, coils are humming
The C27 I am referring to is the largest capacitor on the main board, a huge
aluminum can, 2200uF if my memory serves me right.
It will have to be replaced along with almost all other electrolytic capacitors in the Beogram.
When you replace it, you will notice it has three ground pins of which two are used and must be connected
together again when you mount the new cap, unless you can find a cap of the exact same
type (which is practically impossible).
hi martin,
sorry, i mistook c27 on the mainboard and c27 on processor board and was mixing up all a bit😳
yes, i exchanged the 2200μF and connected minus towards c20 minus to close the gap due to the missing connection with the new cap.
i will check solder joints and the ribbon cable tomorrow.
thanks a lot for your help!
jens
i double checked and resoldered all connectors and measured through the ribbon cable between processor and mainboard. everything seems ok here.
then i started renewing transistors and the op-amp in the drive circuit, by the state i´ve reached till now nothing changed in the behavior of the gram:
it starts spinning slowly as soon as it is pluged in and with a vinyl on the platter i realised, the speed is not 100% stable, but something like an oscillating fault like every two seconds.
i think i wil go on with the transistors in the drive circuit...   just can`t find a replacement for the J175...
0tr2, 0tr3 (the ones on the bottom of the gram) and the bd438 on the small pcb still become rather warm when running.
i´m a bit puzzled, if the fault comes from the cpu giving wrong signals or if it is through the drive circuit?????
jens
Please don't replace components in panic, you may introduce new faults.
Is the tachodisc OK ? Is it a steel disc or a photographic ?
Are the sensor pulses from the tachodisc opto OK ?
hi martin the tachodisc is a new one, steel, i´ve got it from you.
my new observation is, that when the gram is plugged to the mains, it turns backwards for a second, then becomes slower and turns then the right way round...
still the coils are humming and the transistors at next to the coils become quite warm.
how can i see, if the signals from the opto are ok? is this possible without a scope?
thanks for your help + patience!
jens
A scope would provide the best view of the pulses but you can try to rearrange
the sensor slightly inwards or outwards and see if it changes anything.
The humming once per revolution is a typical symptom of a bad
tachodisc (not in this case unless some holes are blocked or the disc is dented) or misadjusted opto sensor.
Alternatively, measure the voltage across the sensor when over a hole and while not  (rotating the spindle
very little by hand).
The eddy-current coils are quite power guzzling ones and if not run correctly, they will easily
draw enough current to blow the fuse.
hi martin!
i measured voltage acros the sensor and it seems to work. when blocked, it reads out ca 15volts, otherwise it´s around 3 volts.
the humming is rather constant and not once per revolution and starts as soon as the gram is plugged to mains, but becomes louder, when play is pressed and the platter tries to go to 33.33 rpm.
jens
You are not using a 60Hz transformer module in a 50Hz area or vice versa ?
Beogram 6006 / 8000 / 8002 won't work with stepup/stepdown voltage converters if the mains frequency
is wrong compared to what is printed on the transformer module. The transformer module needs to match the local
mains frequency.
I wish I could guide you further, but I think this is one of the cases where a trained
technician needs to take a look at it.
hi martin!
no, it´s the right transformer, and as said after i replaced the caps, it worked perfectly for nearly two years, problems just came up last week.
i think i will put the beogram off the desk for some days and give it another try then...
thanks a lot martin for help and patience!
have a nice weekend!
jens
