Hi all,
I finally received my new-to-me 8000 system (beomaster 8000, Beocord 8002, Beogram 8000, two rosewood M100 (huge!) and four rosewood wall hanging P45s. All the components are in excellent cosmetic condition but I do find a couple of functional issues I need help with. After cleaning and relube the Beocord 8002 appears to function properly but has no sound output. I have tried it with two different receivers (the BM8000 and a BM3300). There is no action from the sound level meter either. The tape counter appears to work and display properly and the unit responds correctly to the datalink commands from both receivers and from the remote control directly. I have removed, cleaned and reinserted all the connectors going to board 3 which I assume is where the problem resides. There is no visual indication of component overheating and no ugly smells while the unit is on and functioning. The 7 pin DIN cable shows continuity on all 7 pins. Anyone have a suggestion as to what to try next to get this otherwise beautiful beast to output sound?
One other mechanical issue is that the tape control door interferes with the spring bar on the inboard side pushing the spring bar down as the door closes. The door does open properly when I press on the outboard side of the spring bar and it does latch properly but I would like to correct the interference issue. It appears that the door must attach by sliding in a dovetail slot and it does appear to be improperly seated in that dovetail on the inboard side where the interference occurs. I don't want to apply too much pressure trying to get it apart if it is attached in some other way. Do any of you know how to remove the door from the hinge or is that even possible?
Thanks for your help.
Jerry
