Beocord 3500 (1988) playback problem
Dear all, I've skimmed the forum here to see if my problems have already been covered. Can't find a great deal of help so hopefully I'm not duplicating...
Anyway, I'm hoping to revive my Dad's Beocord 3500 with a view to probable inheritance.
Problem:
When the unit receives mains power it whirrs, initially, then quietens down again.
Without a cassette inserted a touch of the 'play button' doesn't raise the pinch-roller or head. I remember previously this would happen - it aided cleaning. Throughout this process the whirring sound is audible.
When a cassette is loaded and the 'play button' touched, no movement occurs just the whirr sound. Rewind and fast-forward fail to work too.
I've removed the base panel and re-fitted the drive belt. This feels quite loose, so perhaps needs replacing. Is there another drive belt located elsewhere within the unit casing?
Furthermore, recently the unit fell victim to an unfortunate accidental coffee spillage. The spillage was mopped up immediately but I fear the damage has already been done. The pictures below show the unit with the touch panel removed and close-ups of the affected area. Could someone let me know if they reckon the unit's dead?
Much respect and appreciation of all your help and comments in advance.
Beofan for many years with a penchant for 1990s audio systems.
I would get some circuit board cleaner or contact cleaner from your local electrical parts store and clean up that corrosion on the circuit board.
I would expect there are a few more belts in the unit (I am not 100%), if you join the site as a member you will get access to the various service manuals which would show you a diagram of the deck.
Certainly at the age of the deck, the belts are most likely in need of replacement.
btw where abouts are you located? Australia?
Andrew
Hi Andrew - thanks for the speedy reply!
I hear you regarding cleaning up the dirt, good call. The capacitor doesn't look like it's blown so perhaps it's still ok?
As for sourcing a diagram I'll have a check around the web for such a thing. There are plenty of B&O shops nearby so I might chance my arm at chatting to one of the store engineers...maybe they'll have a diagram or two I could take a gander at.
I hope I can get this working again - it's a great deck!
Oh, by the way I'm based in London, UK.
Did I say something kinda Aussie??  😕
Hi Pepps
be careful if you are going into the beocord much deeper as almost certainly their will be some shorting damage to the other side of the pcb "copper foil" side you can gain access via the removable rear cover "note toqux bits and an internal bonding lead " if my memory serves me correctly on the back cover if you are unsure what to do i can probably sort it out for you.
Regards Maurice
I agree, it looks fixable.
I like to use an ultrasonic bath for cleaning things like this but less will probably do.
You may need to dismount (and eventually replace) the affected jumpers and the resistor but
that shouldn't be too difficult. A stiff brush, IPA (IsoPropanol Alcohol) and paper towels to suck up
the mess.
The other fault sounds like a belt problem. Two different types of decks were used. I can supply
new belts for both types.
Project update:
All - many thanks for your advice. I've had the unit in pieces and it does indeed seemto be belt-related. There's a small belt located on the underside of the cassette deck, accessible by removing the rear panel. This presents no problem to replace. The tricky one is located inside the cassette chassis itself. This is much thicker than the other one mentioned previously, approx. 5mm in width. I presume this is the primary drive belt?
Can anyone suggest the best way to access and change this belt?
I'm not worried about getting in and carrying out the work, but as I slowly took the Beocord apart to get to this stage I spent a good deal of time marvelling at the genius behind this deck - it's built in such a clever way, designed with such cunning! Consequently I think that tackling the more complicated aspect of the cassette chassis itself may well present some tricky access issues - if somone could let me know of any known pitfalls before I start it'd be great!
Oh and where's the best place to get belts?
I actually already told you that I can supply belts.
They are available as a set and instructions with text and photos can be included.
Your deck must be the three belt version so there's one more belt that you haven't
found yet (not the one for the motorized lid).
One or more belts are custom produced to size, elasticity and friction so I cannot tell
you for sure if they are available elsewhere.
Maybe from B&O but I doubt it.
Sorry Martin - mis-read your post. That's excellent news. I'll PM you for further details.
Thanks!
pepps
Project update 2:
I received new belts, quite pricey! The packaging did come with a very comprehansive instruction sheet with picture, which was very good. Only small belts included though, no replacement for the main, large belt.
Anyway - I fitted them and sadly when I activated the deck and pressed 'play' the mechanism moved almost into position, but didn't quite make it. Then a small plume of smoke appeared out of the rear of the unit!
I disconnected it from the mains.
I still have a broken Beocord.
If anyone else has any other suggestions please let me know.
Thanks all.
The set contains all tapedeck belts for your version of the Beocord 3500.
That's three in total;
- Capstan belt
- Motor to idler
- Left reel to motion sensor
The cost of the complete set with packing/postage is apprx that of one belt alone (when
they were still available from B&O, that is).
Custom produced belts does not come cheaper and I make no money on selling belts.
Sorry to hear that something didn't go well.
Have you located the source of the smoke ?
Did you fix the other issues ?
